Can we set a config_db in environment and get in sequence body()?
Can we set a field in config_db in environment in build_phase() and get in sequence body()?
In reply to baberali:
Yes, you can use the uvm_config_db as a global resource, or any path you want based on strings. See Config/ConfiguringSequences | Verification Academy
