Can we randomize 2-D array using std::randomize()?
Hello,
I want to randomize 2-D array,
let us say,
rand data [3][3]
such that entire row and column won’t have any repeated value. (Just like Sudoku)
In our case,
1 3 2
2 1 3
3 2 1
But it should be with std::randomize() or any other run time randomization method but not object randomization.
In reply to bonny1989:
class sudo;
rand bit[1:0] a[4][4];
rand bit[1:0] b[4][4];
constraint u_a0 {unique {a[0]}; } //unable to use foreach on this for some reason
constraint u_a1 {unique {a[1]}; }
constraint u_a2 {unique {a[2]}; }
constraint u_a3 {unique {a[3]}; }
constraint u_b0 {unique {b[0]}; }
constraint u_b1 {unique {b[1]}; }
constraint u_b2 {unique {b[2]}; }
constraint u_b3 {unique {b[3]}; }
constraint u_ab0 {foreach(a[i,j]) a[i][j] == b[j][i]; }
endclass:sudo
module sudoku();
sudo i_sudo = new();
 repeat(3) begin
   i_sudo.randomize();
   foreach (i_sudo.a[i]) $display("a is %p", i_sudo.a[i]);
endmodule:sudoku
but not object randomization ?? oops I did not see this…
anyway copy-paste the constraints under std::randomize(a,b) with {…constraints here…};
//constraint u_a0 {foreach (a[i]) unique {a[i]}; } //unable to use foreach on this for some reason
I would prefer something like above, instead of unrolling - your simulator might support…or am I missing something ?
output for 3 loops above
a is '{'h3, 'h1, 'h0, 'h2}
a is '{'h2, 'h0, 'h3, 'h1}
a is '{'h0, 'h2, 'h1, 'h3}
a is '{'h1, 'h3, 'h2, 'h0}
a is '{'h1, 'h0, 'h3, 'h2}
a is '{'h2, 'h3, 'h1, 'h0}
a is '{'h3, 'h2, 'h0, 'h1}
a is '{'h0, 'h1, 'h2, 'h3}
In reply to ssureshg_:
Thanks a lot for response.
But that is what I want without randomizing object.
Please suggest if you have any other solution. :)
same thing will work with std::randomize, as you asked for
unique {a[0]}; //you can use foreach here - I have problem with simulator
unique {a[1]};
unique {a[2]};
unique {a[3]};
unique {b[0]};
unique {b[1]};
unique {b[2]};
unique {b[3]};
Hello,
Thanks for your help. It worked with fixed size array but I feel it is not working wit dynamic 2-D array.
Here is the below code I tried:
module top();
int d;
d = new[4];
// Creating individual array index
foreach(d[i])
d[i]=new[4];
// Randomizing array
std::randomize(d);
endmodule: top
And it gave me below error:
Error-[UARC] Unsupported argument to randomize call
testbench.sv, 15
“d”
Arg #1 of std::randomize “d” is unsupported mixed array
So, is it like that randomize doesn’t work with 2-D dynamic array?
Thanks.
An “unsupported” error message usually means what you are doing is correct, but the tool in use has not implemented it. Please contact your tool vendor.
Oh Okay.
Just tried, didn’t work with VCS but works fine Questa.
Thanks Dave!!
Oh Okay.
Thanks Dave!!
Having the 2D array with fixed size dimension type seems to be working with std::randomize() with VCS…
module top();
    int d[4][4];
        std::randomize(d);
endmodule: top
And the 2D array with mixed dimension types is working from class based randomization…
module top();
    class cls;
        rand int d[][];
        constraint cons_define_sizes {
            d.size == 4;
            foreach (d[i])
                d[i].size == 4;
        constraint cons_rndomize_arr_mem {
        cls obj = new;
        obj.randomize;
endmodule: top
