HI,
I have some DPI file which is not compile properly by Modelsim/Questa.
Is it possible to run pre-compiled file using DPI.
Basic requirement is to read from keyboard during run time, using any method, please suggest
HI,
No one can help you when you say something is not working and do not explain what it is that is not working.
You should read Appendix E of the Questasim User Manual, section Compiling and Linking C Applications for Interfaces
Thanks for the comment, I failed to find information example on how can I directly load object file.
In addition to this could you please look into this also
https://verificationacademy.com/forums/systemverilog/taking-input-keyboard-during-runtime-one-possible-solutions-dpi-c-does-not-work-me-…-any-more-solutions
