Can we covergroup inside a monitor
In reply to Vickyvinayk:
Please use code tags making your code easier to read. I have added them for you.
You need to declare a covergroup before you call its constructor, so the declaration needs to be moved up to the top.
One defines covergroup sampling by either declaring it as part of its declaration or explicitly calling its sample() method, but not both.
Finally, we normally recommend creating a separate coverage collector class that is fed by an analysis port in your monitor.
