The following task, I think a_item_h will be copied to t.
and the change of t will not have effect to a_item_h .
but actually a_item_h changed to the value set by the task.
I think task set_item( int a,int b, ref a_item t); will act like this.
Can anyone help me on this,thanks.
class a_item extends uvm_sequence_item;
rand bit [7:0] a_data;
rand bit [7:0] b_data;
`uvm_object_utils_begin(a_item)
`uvm_field_int(a_data,UVM_ALL_ON)
`uvm_field_int(b_data,UVM_ALL_ON)
`uvm_object_utils_end
function new(string name="a_item");
super.new(name);
class a_seq_base extends uvm_sequence;
`uvm_object_utils(a_seq_base)
a_item a_item_h;
int a;
int b;
function new(string name="a_seq_base");
super.new(name);
virtual task body();
`uvm_fatal(get_type_name(),"MUST override this class")
class a_seq extends a_seq_base;
`uvm_object_utils(a_seq)
function new(string name="a_seq");
super.new(name);
task set_item( int a,int b, a_item t);
t.a_data = a;
t.b_data = b;
uvm_sequence_item tmp;
tmp =create_item(a_item::get_type(),m_sequencer,"req");
void'($cast(a_item_h,tmp));
start_item(a_item_h);
a_item_h.randomize();
a_item_h.a_data = a;
a_item_h.b_data = b;
$display("--a_seq body0----$$$$$");
//set_item(a_item_h,10,100);
set_item(10,100,a_item_h);
`uvm_info(get_name(),$sformatf("%s",a_item_h.sprint()),UVM_LOW)
$display("--a_seq body1----$$$$$");
finish_item(a_item_h);
