Hi all,
I need to force signals in DUT in my tests, however my tests are packed in a package, so I can't use "$root.a.b..." to force signals directly, is there a solution? thx!
Hi all,
Add an interface class to your package
interface class abstract_forces;
// this could be parameterized and accept arguments.
pure virtual function void apply_forces;
Create a module that has the functions that do the forces to the DUT, and inside that module, construct a concrete class that could can add via the config_db and call from your test.
module DUT_forces;
import uvm_pkg::*;
import test_pkg::*;
function void forceset1;
force $root.a.b.c = 0;
force $root.d.e.f = 0;
class concrete_set1 implements abstract_forces;
forceset1;
concrete_set1 h1 = new();
initial uvm_config_db#(DUT_api)::set(null,"*","set1",h1);
function void forceset2;
force $root.g.h.i = 0;
force $root.j.k.l = 0;
class concrete_set2 implements abstract_forces;
forceset1;
concrete_set2 h2 = new();
initial uvm_config_db#(abstract)::set(null,"*,"set2",h2);
Then in your test class, you get the concrete class object and call the forces() method
class test extends uvm_test;
abstract_forces f_h;
function void build_phase(uvm_phase);
if( !uvm_config_db #(abstract_forces)::get( this , "" , "set1" , f_h; ) ) begin
`uvm_error(...)
f_h.apply_forces;
endclass :test
Thanks Dave! I 'll try it.
