Certain component is throwing warning during compile time, so can I disable warning messages of that particular component during compile time?
In reply to tech_savvy:
If you do not show the warning it is impossible to give you an advice.
But you should consider any warning.
You should solve this issue. It seems to be important.
If you want to suppress this warning, do not create this component, then the warning is away.
