Can I constrain a variable with hard constraints for valid values, and then add a dist constraint for distribution?
If so can that additional constraint be soft?
In reply to nshames:
It might help and should be easy to create a small example of what you want to do. A dist constraint has both a hard and soft parts to it. The selection of values/range can be hard or soft, but the weights are always soft.
Sorry, you’re right, of course.
Very simple:
int field;
constraint hard_vals{
field inside {0,256,512,1024};
constraint weights{
soft field dist { 0:=2,256:=4,512:=1,1024:=3};
Does constraint hard_vals enforce a uniform distribution or, barring any other constraints, will the weights constraint be enforced?
OK, that is much easier to understand. This is actually something that is currently being clarified as part of an enhancement to the P1800-2023 LRM. The inside operator does not imply any kind of uniform distribution with respect to other constraints. The constraint
weights will honor the dist regardless of being a hard or soft constraint.
