UVMC-commands (like uvmc_wait_for_phase) can only be called in a SystemC thread.
It would be interesting to wait for the build-phase to complete before getting some UVM configuration values and depending on them decide whether a connection should take place via uvmc_connect or not.
For example:
SC_MODULE(sc_top)
my_model_type my_model;
SC_CTOR(sc_top) : my_model("my_model", sc_core::sc_time(10, sc_core::SC_NS))
SC_THREAD(wait_for_uvm_phases);
void wait_for_uvm_phases()
wait(SC_ZERO_TIME);
UVMC_INFO("SC_TOP",(string("Waiting for build to finish")).c_str(),UVM_HIGH,"");
uvmc_wait_for_phase("build", UVM_PHASE_DONE);
UVMC_INFO("SC_TOP",(string("Build phase ended")).c_str(),UVM_MEDIUM,"");
// Get a configuration int from the test to see if the analysis port should be connected
if (<pseudo-code to get int from UVM config_db and compare with 1>) {
uvmc_connect(*my_model.m_analysis_port, "my_model_ap");
However, when running it I receive a simulation error that claims that a SystemC-quickthread accessed protected stack guard memory. uvmc_common seems to be involved. Is what I am trying to do even theoretically possible? If so, do I need to “split” the uvmc_connect in port generation in the static part (SC_CTOR) and binding (thread)?
