How to call UVM phases in top module without using run_test function?
In reply to kulvinderrawat:
If you do not want to call run_test you have to take care that all run tasks are called in the right order. This is a lot of effort you have to spend. I’m not sure that this is your intention.
Yes, the intention is same. We need to integrate the BFM (which is developed in UVM) inside SV environment.
I don’t know how your BFM looks like, but if it is developed as a UVM device you should be able to integrate this in your testbench.
What do you mean with SV testbench?
