Hi Dave,
Who Calls the build phase of each components in UVM hierarchy?
The build_phase() method for each component is called top-down by the UVM “root”.
What actually happens is that run_test() causes the uvm_test object to be created, then it’s build_phase() is called. The test’s build_phase causes the uvm_env to be created, which adds it to the list. Once uvm_test.build_phase() returns, the UVM looks for any additional components, so it now sees the uvm_env. It calls the env’s build_phase(), which creates agents, etc. This continues until all created components’ build_phase() methods get called, then the UVM continues and calls connect_phase() for all components (bottom-up).
In reply to tfitz:
Can you please explain how the connect_phase() is bottom-up ?
In uvm_test.connect_phase() - we have nothing to connect.
In uvm_env.connect_phase() - assume that we connect the input_monitor with scoreboard predictor and output_monitor with scoreboard comparator -
input_monitor.analysis_port.connect(predictor.analysis_export)
output_collector.analysis_port.connect(comparator.analysis_export)
In uvm_agent.connect_phase() - we connect the driver to the sequencer
uvm_driver.seq_item_port.connect(uvm_sqr.seq_item_export);
In this case as the connect_phase() is called in the below order
1)uvm_test.connect_phase()
2)uvm_env.connect_phase()
3)uvm_agent.connect_phase()
The first the (input_monitor gets connected to predictor) and then (output_collector gets connected to comparator)
Then later at last the driver gets connected to sequencer
So this connection look top-down. Please correct me
Thanks in advance
In reply to georgean:
I have attached a small example that demonstrates the calling order for some of the UVM phases given a simple hierarchy. A better term would have been depth-first traversal instead of bottom-up.
Note that calling the connect() method is not the same as calling the connect_phase(). The connect() builds a database of connections to be made between components. The order that you call the connect() methods does not matter as long as both ends of the connection have been constructed before making the call, and all connect() calls have been made before the end of the connect_phase. Conceivably, you could call the connect() method during the build_phase() or constructor, as long as the other requirements are met.
Hi Dave,
Can you please point me to source which explains the differences between connect() and connect_phase(). Also is there similar explanation for build and build_phase().
Thanks
Subramaniam
In reply to ssubramaniam:
The UVM reference manual is your source. connect_phase() is a virtual method of uvm_component, and connect() is a method of uvm_port_base. They are two different methods of two different classes. The OVM was even more confusing because it use the same method name connect() in two different classes.
Sometimes, its difficult to keep all the method names unique, especially when different people have their hands many areas of the code.
In reply to tfitz:
Hi tfitz,
Does the execution order of .build_phase() depend on the order the components were created?
// Parent component
function build_phase();
a = new();
b = new();
end build_phase();
UVM will execute a.build_phase() first, and then execute b.build_phase()
In reply to hoalu:
The build_phase is a function, executed in 0 time. If a or b is constructed first doesn’t matter and it might depend on th eimplementation in the simualator.
Why does it depend on simulator? I think the order here is important and it being handled by UVM? In UVM, it traverses to build a, all sub components of a (topdown order of a tree) then b and all sub components of b.
In reply to chris_le:
My understanding is different. Topdown means starting on the toplevel it goes down, creating all components on a certain level and the proceed going to the next level. Then it does not matter if ‘a’ iss constructed first or ‘b’.
No, UVM build component using “pre-order of a tree traversal” (top-down).
From the parent component F, it traverses to build in order: B, A, D, C, E, G, I, H component (source picture from wiki)
I think it doesn’t matter for the case when there are multiple instances to be created at the same level , so in the above given case whichever is created first (a or b) doesn’t matter.
So for all same level in the hierarchy whichever is created fisrt doesn’t matter .
This is exactly why there is a separate connect_phase() in UVM. During build_phase(), the exact order of building doesn’t matter. The point is that, starting with F in your diagram, its build_phase() method will create B and G. Note that these two uvm_components are effectively independent of each other at this point, so it doesn’t matter in which order they are created. If you are depending on them being created in a particular order, then you’re doing something wrong.
There won’t be any useful information to be had from B or G until their build_phase() methods have been called, which will likely include some call(s) to the uvm_config_db to configure them. This is also why the uvm_config_db is a separate thing rather than trying to pass parameters directly down to a child component when it is created (there are other logistical reasons why this isn’t a good idea). So, even if you wanted to, you couldn’t get any useful information out of B until after its build_phase() method completes. Of course, any such information would already be known to F which would have set it in the config_db to begin with, so F could just as easily use the same information to configure G, so again it doesn’t matter in which order B and G are created.
The same argument applies recursively down the tree. A and D are created by B.build_phase() and it doesn’t matter in which order they are created. Note that I would be created by G.build_phase() at the “same level” as A and D, and all of them are independent.
After the build_phase completes and all components have been configured and created, we call connect_phase() which relies on components having been created so that the ports/exports exist so that they can be created.
Any last-minute tweeking required before main_phase() starts can be handled by end_of_elaboration_phase().
In reply to tfitz:
Thanks for clarifying.
- In fact, the parent component adds its children to associate-array by name, and the created order can be predictable:
class F extends uvm_component;
B b_m;
G g_m;
g_m = G::type_id::create("g_m", this);
b_m = B::type_id::create("b_m", this);
Associate children array of F component always will be (even we created g_m before b_m):
uvm_component m_children[string] = {
"b_m": b_m,
"g_m": g_m
Everytime F component gets next child to process the build_phase, B component is always the first one according to the array above. After all children of B component complete, G will be processed.
- I wanted to clarify the idea: “All components at the same level must be built before going to the next level”. Actually, this idea is not correct, right? In my example, A, D and I component are same level (A, D are children of B; I is child of G), but I component will never be processed at the same time as A and D.
The fact that your current UVM implementation creates components in a predictable order does not change the fact that you should NOT rely on components being created in any particular order. With the standardization of IEEE 1800.2, much of the internals of UVM ARE no longer dictated by the standard in order to give developers and vendors the opportunity to optimize UVM implementations.
The only thing you can rely on is that a parent will create it child(ren) in its build_phase() method, and the child(ren)'s build_phase() method will run sometime later, after completion of the parent’s build_phase(). PERIOD.
If you do anything else, it might work now, but there is no guarantee that it will work with your next version of UVM. And if it doesn’t work in the future, it will be because you broke the rules, not because the UVM implementation changed.
I can’t say this strongly enough:
DO NOT ASSUME ANY ORDER TO THE EXECUTION OF THE BUILD_PHASE() METHODS OF ANY UVM COMPONENTS OTHER THAN THAT A PARENT’S BUILD_PHASE WILL COMPLETE BEFORE THE CHILD(REN)'S BUILD_PHASE GETS CALLED.
Thank you so much for this example. I have few doubts about the code you shared with us.
import uvm_pkg::*;
`include "uvm_macros.svh"
class grandchild extends uvm_component;
`uvm_component_utils(grandchild)
super.new(name,parent);
`uvm_info("new", "constructor",0);
`uvm_info("build", "phase",0);
`uvm_info("connect", "phase",0);
`uvm_info("run", "phase",0);
function void report_phase(uvm_phase phase);
`uvm_info("report", "phase",0);
class child extends uvm_component;
grandchild gc1,gc2;
gc1 = grandchild::type_id::create("gc1",this);
`uvm_info("build", "created gc1",0);
gc2 = grandchild::type_id::create("gc2",this);
`uvm_info("build", "created gc2",0);
class env extends uvm_env;
`uvm_component_utils(env)
child c1,c2;
c1 = new("c1",this);
c2 = new("c2",this);
endclass : env
class test extends uvm_test;
`uvm_component_utils(test);
env e;
e = new("e",this);
uvm_component tmp=uvm_top.find("uvm_test_top.e");
env e;
$cast(e,uvm_top.find("uvm_test_top.e"));
e.print();
endfunction // report_phase
module top;
env e2;
e2 =new("e2",null);
run_test("test");
Inside the test class, env class creation of objects has been done differently. I mean
we can use new, but should we not use the protocol; using
{ class_type::type_id::create(name of the object,this); } -
Inside the top module an object of env class has been created. I didn’t understand, why?
env e;
e.print();
Here when we were finding whether any object named e has been created or not we used the
path uvm_top.find(“uvm_test_top.e”) . Why didn’t we use
uvm_test_top?find(“uvm_test_top.e”)? And also return type is uvm_component . Is the reason
as same as we know for the do_copy method having argument uvm_object i.e. implementation
of factory or something else?
In reply to Shubhabrata:
- Yes, using create() instead of new() is the proper protocol. I was trying to be quick in typing.
- This was just a contrived hierarchy. You are allowed to create uvm_components outside the test hierarchy as long as you do it before leaving the build_phase.
- “uvm_test_top” is the component string name given to the instantiated “test”. uvm_top is a variable that contains the uvm_root of all components with a null parent. In this case the uvm_test created by run_test(“test”) and the “e2” object are two trees under uvm_top. (uvm_top was actually deprecated in IEEE UVM 1800.2 and you now need to use uvm_root::get() instead)
A test extends a base test
both the test and the base test have a task reset_phase(uvm_phase phase)
- base test is starting reset_sequence_1 in reset phase
- main test extending base test is starting reset_sequence_2 in reset phase
after the main test is complete- which reset sequence has taken effect?
Are we allowed to have same phase( reset_phase in this example) in main test and the base test? How would the compile resolve sequence starts in such a scenario?
