Is there any support for callback in UVM or this is a completely user defined construct that testbench writers need to use?
If UVM does support, an example would help a lot.
In reply to verif_learner:
Callbacks should never be used in a UVM environment as they introduce unneeded complexity and dependencies which limit re-use. Instead, TLM communication should be used to co-ordinate actions between components.
In reply to cgales:
Sure. That’s what I thought while going through a book on SV based verification.
The Story with the callbacks is a little bit more special.
The pre_do, mid_do and post_do helps us to make modifications in RO sequences.
It is highly recomended to deal with these callbacks when extending VIP sequence definitions.
Sure. As far as the callbacks available in the framework, yes.
Uuser defined callbacks, probably no.
This is how I have interpreted …
