Callback
Hello,
Can anyone explain me the usage of uvm_callback_iter#(mycomp, mycb)? In which scenario it will be used and how to use it?
In reply to MageshV:
This section Callbacks Classes should give you a fair idea on what is it all about …
Top-level idea: To modify “certain” behaviors of UVM components without modifying the original code… Common example is to enhance a normal agent to inject error scenarios
Spicing up your UVM driver: noise injection made easy with callback iterators (verification-explorer.com)
