Calculating probability for solve x,y before z
Hi Forum,
I am trying to calculate the probability of each possible output using solve before constraint
Solve before using 2 random variables solve x before y
rand bit x;
rand bit [1:0] y;
constraint a2 { (x == 0) -> (y==0);
                solve x before y; }
Within solve x before y as x appears first, I calculate the probability starting with x
As x could be either 0 or 1 i.e probability of each would be (1/2)
When x is 1 , y could be 0/1/2/3.
Hence the probability of y == 0/1/2/3 ( when x is 1 ) would be (1/2) divided into 4 equal parts
x y Probability
0 0 1/2
0 1 0
0 2 0
0 3 0
1 0 1/8
1 1 1/8
1 2 1/8
1 3 1/8
On enhancing the solve before using 3 random variables solve x,y before z
rand bit x;
rand bit [1:0] y,z;
constraint a3 { (x == 0) -> { (y==0); (z==0); }
                solve x,y before z; }
x y z Probability
0 0 0 ?
0 0 1 0
0 0 2 0
0 0 3 0
0 1 0 0
0 1 1 0
0 1 2 0
0 1 3 0
0 2 0 0
0 2 1 0
0 2 2 0
0 2 3 0
0 3 0 0
0 3 1 0
0 3 2 0
0 3 3 0
1 0 0 ?
1 0 1 ?
1 0 2 ?
1 0 3 ?
1 1 0 ?
1 1 1 ?
1 1 2 ?
1 1 3 ?
1 2 0 ?
1 2 1 ?
1 2 2 ?
1 2 3 ?
1 3 0 ?
1 3 1 ?
1 3 2 ?
1 3 3 ?
How do I calculate the probability of each valid combination ?
My intuition is that out of the 5 valid combinations of {x,y} as {0,0} / {1,0} / {1,1} / {1,2} / {1,3}
the probability of each combination would be same i.e equal to (1/5).
Hence probability of 1st row ( x == 0 and y == 0 and z == 0 ) would be (1/5)
For the remaining 4 combinations of {x,y} there are 4 possible values of z.
Hence the probability of each of the last 16 rows would be (1/5) x (1/4) i.e (1/20)
(Q) Is my understanding correct ?
The probability would be easier to comprehend if you removed the rows with zero probability. In that case, you would observe that the probability of y having the values 1/2/3 would be 1/5 each. However, since y==0 appears twice, it has a probability of 2/5.
Similarly, in the second example, there would be 17 rows. For each variable y and z, the values 1/2/3 appear four times, so their probability would be 4/17. The value 0 appears five times, so its probability is 5/17.
Dave,
I am confused with the probability you have mentioned.
As my understanding the above probability is without using solve before
rand bit x;
rand bit [1:0] y;
constraint a0 { (x == 0) -> (y==0); } //  No solve before
With a0 the probability of each combination would be same i.e (1/5)
x y Probability
0 0 1/5
1 0 1/5
1 1 1/5
1 2 1/5
1 3 1/5
(Q) On adding solve x before y (constraint a2 ) wouldn’t the probability change to ::
x y Probability
0 0 1/2
1 0 1/8
1 1 1/8
1 2 1/8
1 3 1/8
If I were to use solve y before x I believe the probability would be
x y Probability
0 0 1/8
1 0 1/8
1 1 1/4
1 2 1/4
1 3 1/4
Sorry I posted before finishing my answer. You are correct in the first example when adding solve x before y, the probability of y==0 becomes 1/2 + 1/8, or 5/8. For solve y before x, the probability of x==0 becomes 1/8.
For the second example, I think you meant to say solve x before y,z as solving x and y together doesn’t make any sense with the constraints you have. Then the probability of y==0 becomes 1/2+1/16 or 9/16
