Is it a good idea to use uvm_event_pool to broadcast reset assertion/de-assertion information across the UVM testbench components (rather than passing through vif)? Would like to trigger a stimuli from sequence, after reset assertion which may be triggered from other random sequences (would like to avoid vif access in sequence, obviously)
Will this cause any chaos as uvm_event_pool is not well protected and can be modified (triggered) from anywhere?
Reset (and clock) signals should be part of your interfaces, and not passed through the UVM hierarchy. The reason for this is that each interface may use a separate reset (and clock), so you want your agent driver/monitor to be cognizant of it’s associated reset.
Stimulus generation should have no dependency on any reset. It is only when the sequence_item reaches the driver that the reset signal is considered. Your first set of sequence_items should occur at time 0.
