Bitwise and of array,array reduction operator
i am trying to assing bitwise and of array to single bit wire
 wire [3:0] mpu_region_vr0       = `MPU_PATH.mpu_region_v_r;///rtl path
 wire      mpu_region_vr             =mpu_region_vr0[0] &
                                      mpu_region_vr0[1] &
                                      mpu_region_vr0[2] &
                                      mpu_region_vr0[3] ;
i tried with the function .and() as well still am getting same error is it tool related issue?
i am getting
Incompatible unpacked dimensions in assignment
Arrays with incompatible unpacked dimensions cannot be used in assignments,
initializations and instantiations.
In reply to abhineet2210:
There are no unpacked dimensions in what you have shown. What is the declaration for mpu_region_v_r?
This should have worked:
wire mpu_region_vr = &mpu_region_vr0;
reg mpu_region_v_r [`REGION_RANGE];
still getting the same error
mpu_region_v_r is an unpacked array that you are trying to assign to mpu_region_vr0, which is a packed array. If the bits line up you can use the streaming operator for unpacked-to-packed array conversion.
wire [3:0] mpu_region_vr0 = {<<{`MPU_PATH.mpu_region_v_r}};
