`define abc(Bus,Enb,Data)
assign (strong1,highz0) = Bus = En ? Data : {$bits(Bus){1’bz}};
What does this statement mean ?
{n{expr}}
means create a concatenation by repeating the expression n times. $bits(Bus) is the number of packed bits of the data type of Bus.
You can simplify this expression with
assign (strong1,highz0) = Bus = En ? Data : 'z;
'z, '0, '1, and 'x are all extended to the proper width based on the context of the assignment target. In this case, Bus.
Is the $bits() a runtime function or parsed at compile/elab time? Can I use it in a parameter definition? For example:
logic [$bits(in_header.set_get_hdr.num_word32)-1:0] wr32_remain;
It seems to compiled OK, but not sure if it works similar to the $clog2()?
Richard
In reply to hctseng:
Yes, as long as the argument to $bits is a fixed sized type, you can use it as a constant expression.
Thank you Dave!
