Hi ,
My parameterized interface is defined as :
interface intf #( parameter LENGTH = 10 , HEIGHT = 20 );
logic [ LENGTH-1 : 0 ] a ;
logic [ HEIGHT-1 : 0 ] b ;
initial $display(" Within %m : LENGTH = %0d , HEIGHT = %0d " , LENGTH , HEIGHT );
endinterface
The interface needs to be instantiated within following module :
module CSR #( parameter LENGTH = 10 , HEIGHT = 20 );
// We Need to Instantiate interface with the Actual Parameters for module CSR
The module CSR is instantiated as :
module CSR_top ;
CSR #( 100 , 200 ) csr() ;
Now the requirement is to to bind the interface ’ intf ’ to specific instance ’ csr ’ via the top_tb :
module top_tb ;
// The overridden parameters to the interface must be the same parameters provided to instance name ' csr ' i.e 100 and 200 .
bind top_tb.u_chip_top.csr_top.csr intf#( LENGTH , HEIGHT ) intf_inst() ;
This does work , however I am confused how is it that there is No error when I write : intf#( LENGTH , HEIGHT )
How does it take the same parameters i.e 100 and 200 as the overridden one in instance : top_tb.u_chip_top.csr_top.csr
