Binding multidimensional array in design
I have a two dimensional array instances of a two dimensional array in design (can be viewed as model of 2D memory array) that I want to access each element of the array from test bench. I am facing issues with using 2D interface port and binding it to each of the instances. I was wondering if anyone have success with such mechanism or any other way to access the array elements.
Thanks in advance.
In reply to anacharya:
Can you provide a sample code of what you have tried and what issues your are running into?
Here is the sample code:
Interface definition:
interface mem_if #(int MEM_WIDTH=64,
int MEM_LENGTH=256)
logic [MEM_WIDTH-1:0] memory[MEM_LENGTH-1:0]
In the test bench:
bind dut.u_des1.u_des2.mem_bank[0].sub_mem[0].mem_wrapper.mem_inst mem_if mem_if_0(.memory(mem_array));
I have 32 mem_bank instances and 32 sub_mem instances.
The elaboration error I’m getting is:
Expression connected to an ‘inout’ port must be collapsible. (in test bench file)
Did this ever get resolved?
I have a similar requirement in my bench.
