Bind usage in System verilog
I have following code in a separate bind file -
bind A: A1_inst A_bind
#(  .P     (P1)
A1_bind_inst (.*);
bind A: A2_inst A_bind
#(  .P    (P2)
A2_bind_inst (.*);
bind A: A3_inst A_bind
#(  .P     (P3)
A3_bind_inst (.*);
Now, A_bind file has code -
bind B B_bind
 # (  .P    (P)
   B_bind_inst (.*);
I am getting error - B_bind_inst already declared in the scope.
I am getting this error two times.
Pls help
In reply to ashish_banga:
You need to give some more context for the bind inside the A_bind file. If it is inside the A_bind module, then each instance of A_bind will try to add the same bind to module B. You probably want to do an instance specific bind to B.
Right. But how to do that?
You need to show more context. Why is the bind statement inside the A_bind module? Can it be moved outside? Where is A instantiated in relation B? If you could show a small example that demonstrates what you are trying to accomplished, then we could show you how.
Ok, let me try,
There is a module C.
module C has multiple instances of module A, named A1_inst,A2_inst,A3_inst.
module A has instance of module B .
There is a bind file for module A , A_bind.
and a corresponding bind file for module B - B_bind .
So, I want different instances of B_bind for each instance of A_bind,as shown in my question
You’re still being lazy in your description of the problem. This is what I mean by showing the complete context of of the situation as I see it.
module A;
   parameter P1=1,P2=2,P3=3;
   B #(.P(P1)) B_inst();
module B #(int P);
   initial $display("%m %d",P);
module A_bind #(int P);
   bind B:B_inst B_bind #(.P(P)) B_bind_inst ();
module B_bind #(P);
endmodule // A_bind
bind A: top.A1_inst A_bind
#(  .P     (P1)
A1_bind_inst ();
bind A: top.A2_inst A_bind
#(  .P    (P2)
A2_bind_inst ();
bind A: top.A3_inst A_bind
#(  .P     (P3)
A3_bind_inst ();
   A A1_inst();
   A A2_inst();
   A A3_inst();
With just a little more code, now we both have something to compile and experiment with.
