Iam trying to create bins using a function just to avoid the repetition. But Iam getting error in below code
function bins_uint bin_creator(int size, int multiple);
bins_uint local_arr;
local_arr = new[size/multiple];
foreach(local_arr[i]) begin
local_arr[i] = i*multiple;
covergroup cg with function sample(trans txn);
efc_obw_cp : coverpoint txn.width {
bins width[] = bin_creator(8,8);
endgroup
The intention of above code is to generate multiples of 8, till 64(which is size). Iam trying to make bins 0,8,16,24,32…64. But iam getting an error. Could anyone please suggest me a better way to do it or why the error is popped up? This is not just for 8 multiple, I want to re-use for other multiples as well
In reply to mbhat:
Please find the error below :
Error-[SE] Syntax error
“/local_vol1_nobackup/coverage.sv”,
411: token is ‘(’
bins width = bin_creator(8,8);
Check your simulator to see the SV LRM (2012 should support using queues and arrays) it is supporting, I believe I the support is to use s queue or array in the RHS of the bins expression, not a function (I could be wrong) , you could try something like this.
class some_cov
bit [7:0] my_bins[$];
bit [7:0] data;
covergroup m_cg;
data_cp : coverpoint data
bins data_bins[] = my_bins;
endgroup
function new (string _name = "", int size);
int count
this.name = _name;
repeat(size) begin
my_bins.push_back((count++)*8);
m_cg = new();
