Behaviour of disabling fork with label across simulators
I am noticing different simulators behaving differently for disable fork with label.
I want to understand the actual interpretation of the IEEE Std 1800-2017, section 9.6 & sub-section 9.6.2.
Here is the sample code.
module disable_fork_check;
  int A;
  int B;
  int C;
    fork : CHECK
    // Thread 1
      forever begin
        @(posedge A);
        if(B == 1)
          $display($time, " B = 1");
    // Thread 2
      @(C == 1);
      $display($time, " DEBUG :: C = 1");
    join_any
    disable CHECK;
    $display($time, " Disabling CHECK");
    A = 0; B = 0; C = 0; #10;
    A = 1; B = 0; C = 0; #10;
    A = 1; B = 1; C = 0; #10;
    A = 1; B = 0; C = 1; #10;
    A = 0; B = 0; C = 1; #10;
    A = 1; B = 1; C = 1; #10;
    $finish;
endmodule : disable_fork_check
When the above code is executed in Sysnopsys VCS 2019.06 or Aldec Riviera Pro 2017.02 the result was;
30 B = 1
50 DEBUG :: C = 1
50 Disabling CHECK
But, when the same code is executed in Cadence Incisive 15.20, the result was;
30 B = 1
50 DEBUG :: C = 1
50 Disabling CHECK
70 B = 1
Which tool is interpreting the IEEE Std correctly?
In reply to thangavelu_bheema:
Majority wins.
