Basic syntax error : Macro `uvm_object_utils_begin is undefined
Hello,
my UVM environnement was recompiling UVM sources each time. it works correctly but was not the clean way to process.
This is why I removed in my source code all lines that include uvm_macros.svh and I keep only “import uvm_pkg::*;” lines.
But now, I have a syntax error in a file that contains one class :
Macro `uvm_object_utils_begin is undefined.
The file with the class is included in a package that contains the line : “import uvm_pkg::*;”
Do I need to import something else to have the right to use uvm_object_utils_begin ?
or is it a problem with my questa configuration ? mti_uvm is correctly declared…
note : I use UVM 1.1d version
In reply to iostrym:
Import and include are two separate concepts which needs to be understood. Read Dave’s article to get a better understanding.
Essentially you want to import the UVM package and include the uvm_macros.svh. DO NOT include the uvm_package.sv.
Thanks a lot.
in fact my UVM code was already correct. I previously already removed the `include the uvm_package.sv that make Questa recompiling all UVM sources.
I did a mistake by removing the `include uvm_macros.svh that is needed. thanks a lot for your help
