I am new to SVA and want to write one plain assertion with the requirement as follows:
There are 2 signals - req and ack.
Between two consecutive assertions of req, ack should be asserted only once.
Please help in writing this simple assertion.
Should i use throughout, first_match or, within operator?
I am confused.
Ashish
sequence s1
//syntax to detect 2 consicutive req signals
endsequence
sequence s2
//syntax to detect one ack signal
endsequence
property check;
@(posedge clk) $rose(req) → s2 within s1;
assert property(check)
$error(“assert failed”)
//the above mentioned syntax could be one option.
//or
sequence s3
//syntax to detect first req followed by an ack and then again req
endsequence
property check1;
@(posedge clk) $rose(req) → s3;
assert property(check1)
$error(“assert failed”);
//you can try this one also
//if I am wrong please feel free to correct me
Naresh
