Backdoor Register Layer Access
In reply to Sanjin_Arsenovic:
You are setting some hdl_path and call then clear_hdl_path:
   m_reg_block_p1.configure(.hdl_path("top.dut"));
   m_reg_block_p1.build();
   m_reg_block_p1.cntrl_reg.clear_hdl_path();
I’d recommend you should call add_hdl_path in your register model.
To check whether a hdl path does exist or not you can call uvm_hdl_check_pth.
