Hi Forum,
I have a single CSR interface through which we read/write registers.The reg_block is accessible to different sequences & components through which we initiate register access.
In my simulation I observe that ISR sequence accesses TAIL_PTR register through UVM_FRONTDOOR at T: 5683.000ns. The read task unblocks at T: 5711.000ns.
My env initiates a backdoor read to the same TAIL_PTR register at T:5686.000ns ( i.e after the frontdoor read has been initiated )
This results in backdoor read completing at T:5711.000ns ( same time that frontdoor read completes )
Curious to know why the backdoor read consumes time, I decided to check code for class uvm_reg
I notice that each uvm_reg class has these 2 properties
local semaphore m_atomic;
local bit m_read_in_progress;
(1) During call to uvm_reg::read internally calls m_atomic.get(1)( via XatomicX(1)) and just before read completes, it calls m_atomic.put(1) ( via XatomicX(0) )
(2) uvm_reg::read calls uvm_reg::do_read which initially assigns m_read_in_progress = 1’b1 and just before uvm_reg::do_read completes it assigns m_read_in_progress = 1’b0
Due to these properties my backdoor read remains blocked till frontdoor read completes.
My intention is that the backdoor read should complete in 0 time so I have one possible solution to this
// Within top_tb
wire [31:0] tail_ptr;
assign tail_ptr = tb_top.rtl_top.<RTL_Hierarchy>.tail_ptr;
assign my_intf.tail_ptr = tail_ptr;// my_intf is accessible via virtual intf
My env would directly read my_vintf.tail_ptr instead of reg_block.TAIL_PTR.read(status,rd_data,UVM_BACKDOOR);
[Q] I am curious if there is any RAL API based solution to this issue ?
Please note that ISR sequence would perform only frontdoor reads (to mimic a real FW) while the env is performing a backdoor read for some checker.
The order of the 2 reads ( env & ISR ) in a simulation is non-deterministic and depends on IO command flow i.e env could perform read before the ISR’s
