Back door access for uvm_mem
Hi All,
How can we add path for memory to access back-door.
There are lot of questions/information on accessing the back door register not for uvm_mem.
I’m looking a back door access of memory derived from uvm_mem.
For an example:
class my_mem extends uvm_mem;
In top reg class:
my_mem_h = my_mem :: type_id::create(“my_mem_h”);
my_mem_h.configure(this,“my_mem_h”);
From test I need a following:
top_block.read(status,read_data_mem,UVM_BACKDOOR);
Now uvm_mem methods to add hdl path:
// Function: add_hdl_path
// Add an HDL path
// Add the specified HDL path to the memory instance for the specified
// design abstraction. This method may be called more than once for the
// same design abstraction if the memory is physically duplicated
// in the design abstraction
extern function void add_hdl_path (uvm_hdl_path_slice slices,
string kind = “RTL”);
  1. How we can do a back-door access here?
  2. How to add a path here?
Any example would be appreciated.
In reply to Geet:
This UVM register user-defined memory backdoor - EDA Playground might be helpful
and this presentation as well Doing Funny Stuff with the UVM Register Layer: Experiences Using Front Door Sequences, Predictors, and Callbacks – DVCon Proceedings Archive
HTH,
-R
In reply to rgarcia07:
I was looking for uvm_mem. Not uvm_reg_backdoor.
Anyways, Got solution by myself by reading several methods on How to add path.
It can be done using providing path in configure method.
my_mem_h.configure(this,“RTL_PATH_TO_LOCATION”);
Still facing below error:
UVM_ERROR /proj/eda/CADENCE/XLM/20.09.009/tools/methodology/UVM/CDNS-1.1d/sv/src/reg/uvm_reg_block.svh(2049) @ 11020.00 ns: reporter [RegModel] Block does not have hdl path defined for abstraction ‘RTL’
I’m trying to access
top_reg_block.my_mem.read(offset,read_data,UVM_BACKDOOR);
Can we not read/write using read method with UVM_BACKDOOR of uvm_mem class?
If anyone has small pseudo code with uvm_mem, Please share.
Were you ever able to find a solution for this? I also experienced the same UVM_ERROR. Thanks!
