In reply to Satputesb:
The following works but it has an issue if B and C occur simultaneously because the order of processing of the fork elements is not predictable. Thus if fork2 is processed before fork1 you can get an OK. The concept demoed here may guide you into a better approach.
module m;
`include "uvm_macros.svh" import uvm_pkg::*;
bit A, B, C, run;
event t0, t1, ta, tb, tc;
/*nLet me re frame the question there are three different "single bit inputs"
Input A1(Single bit);
Input A2(single bit);
Input A3(Single bit);
All these inputs arrive in specific sequence. which
Fisrt A1 is asserted and kept high.
Then after sometime A2 is asserted and kept high.
And then A3 is asserted and kept high.
These inputs are externally driven.
I would like to write assertion for checking if these are being asserted in specific sequence. */
task automatic t_abc;
automatic bit a, b, c, oka, okb, okc; // history + status
-> t0; // debug
fork
fork1: begin
@(A) a=1;
am_A1_B0_C0: assert(!B && !C && !b && !c) oka=1;
-> ta;
fork2: begin
@(B) am_A1_B1_C0: assert(!A && !C && a && !c) okb=1;
b=1;
-> tb;
fork3: begin
@(C) am_A1_B1_C1: assert(!A && !B && a && b) okc=1;
c=1;
-> tc;
join
am_ABC: assert(oka && okb && okc);
-> t1;
always @(posedge run) begin
t_abc();
bit a0, b0, c0;
repeat(250) begin
#20
if (!randomize(a0, b0, c0, run) with
{ a0 dist {1'b1:=1, 1'b0:=4};
b0 dist {1'b1:=1, 1'b0:=4};
c0 dist {1'b1:=1, 1'b0:=4};
run dist {1'b1:=1, 1'b0:=15};
#5; A=a0; B=b0; C=c0;
$stop;
Real Chip Design and Verification Using Verilog and VHDL($3) https://rb.gy/cwy7nb - Papers:
Verification Horizons - July 2020 | Verification Academy - SVA Alternative for Complex Assertions
