Hi VA,
Found an issue in my verification testbench.
Created an associative array in my env class in build_phase.
Array was initialized with 2048 items using the keys of the associative array.
class custome_env extends uvm_env;
custome_ref_model ref_model;
bit[512-1:0] cache_image[int];
function void build_cache_image();
for (int unsigned ii=0; ii < 2048; ii++) begin
cache_image[addr] = {16{ii}};
addr += 64; //addr in byte resolution.
Later in connect_phase of my custome_env class linked this array to same array type and name in my ref_model class:
ref_model.cache_image = this.cache_image;
class custome_ref_model extends uvm_component;
During the test run, the associative array was modified many times in the ref_model class.
Unfortunately found in the check_phase of the test that the associative array in ref_model class is different than the one defined in the custome_env class.
How is it possible?
Why the items of associative array in the custome_env class was not being modified during the test run?
Michael
