Assigning a constant value to an unpacked array
Hello,
I need to assign a constant value ‘0’ to an unpacked array.
My array is defined as “reg [3:0] q [1:0]”.
Can this be done using the streaming operator?
What is the standard way of doing this?
Thank you.
This will assign 0 to every element in an array:
q = '{default:0};
By the way, you should stop using the reg keyword. Use logic or bit. See What's the deal with those wire’s and reg’s in Verilog - Verification Horizons
To clarify, you want to make every element in your array the contant value ‘0’
module test();
        reg [3:0] q [1:0];
                $display("q is %p",q);
                q = '{2{'0}};
In reply to alexgran:
Thanks.
That did the trick.
And you’re right, I should use bit instead.
Old verilog habits die hard :)
Maybe it works only inside an initial block? I tried putting this code inside my clocking block and did not seem to work. But the q = '{default:0}; worked.
