I’m trying to assign localparam with $bits() on a struct inside a union inside an interface from my ports.
The motivation for that is to make my module robust to width changes in the irq_bus inside the interface.
It doesn’t seems to work.
Is it possible to do that in any other way?
meaning, can I change bus width inside interface and pass that info to my module at compilation stage?
module interrupts_serializer
output var logic [IRQ_SERIALIZED_DATA_WIDTH-1:0] data,
output var logic valid,
interrupts_if irq_if,
input var logic sys_clk,
// THIS LINE FAILS....
localparam integer IRQ_BUS_WIDTH = $bits(irq_if.irq_union.irq_bus);
localparam integer DETECTION_GRANULARITY = 128;
localparam integer IRQ_BUS_DETECTION_RESIDUE = IRQ_BUS_WIDTH % 4;
localparam integer IRQ_BUS_TRANSMIT_RESIDUE = IRQ_BUS_WIDTH % 8;
import general_pkg::*;
interface interrupts_if;
typedef struct packed {
logic pvt_sensor_threshold_irq;
logic [NUM_OF_BANDS-1:0] mac_phy_gp_if_irq ;
logic [3:0] external_irq_out_synced;
logic shram_addr_irq;
logic [NUM_OF_BANDS-1:0] ulpr_report_fifo_not_empty_irq ;
logic [1:0] pcie_irq;
} interrupts_struct;
typedef union packed {
interrupts_struct irq_struct;
logic [$bits(interrupts_struct)-1:0] irq_bus;
} interrupts_union;
interrupts_union irq_union;
endinterface
