In reply to maxiale:
Is there any difference in this code between syntax?
a && b && c |-> v
a ##0 b ##0 c |-> v
There is NO difference from a simulation point of view.
The difference is in the interpretation or reading of the sequence. Specifically,
"a && b && c " reads like a 3-input AND gate.
"a ##0 b ##0 c " reads as a series (or sequence) of ON/OFF switches:
____________/ __________/ _______/ _______
a b c
or in English, "a", and then immediately "b", and then immediately "c", ...
And some similar question, I did some research in variable assertions, and found Ben Cohen example code from that topic :
https://verificationacademy.com/forums/systemverilog/usage-variable-delay-sva
Let’s take this one:
property p_range_equivalent; // Equivalent implementation
int local_v; // this is an internal local variable defined by the tool
$rose(a) |-> (1, local_v = v-N)
##N 1'b1 ##0 first_match((1, local_v=local_v - 1)[*0:$] ##1 (b || local_v<=0))
##0 b;
I don’t understand why we need to write this code
…##N 1’b1 ##0 first_match…
Is it not similar like ##N first_match ?
And as I ask before can we write && b, instead ##0 b.
You are correct that
##N 1'b1 ##0 first_match((.. // IS the same as
##N first_match((..
When I wrote the code, my train of thoughts was like this:
$rose(a) |-> (1, local_v = v-N) ##N 1'b1 ##0 first_match((..
Following a rose(a), I set the local variable and then wait for N cycles.
At that "stepping stone" (the ##N 1'b1 ) I then continue (with the ##0 )with this complex iterations with repeats and tests. Thus, in my mind, I visualized the (##N 1'b1) as a pause or "stepping stone".
But, you are correct, it could have been replaced with
##N first_match((..
Defining properties is more about specifying requirements; syntax have connotations in the expressions of these requirements.
