Brurya
September 1, 2024, 4:55am
1
I need to write an assertion that wait at least X ns between rose(a) and rose(b).
X is a variable that come as argument.
it is illegal to write $rose(a) ##[x:$] |-> $rose(b)
I tried this code:
sequence delay_seq(v_delay);
int delay;
(1,delay=v_delay) ##0 first_match((1,delay=delay-1) [*0:$] ##0 delay <=0);
endsequence
aasert_Ts_1 : assert property (@(posedge assert_clk) $rose(a)) |-> delay_seq(10) |-> $rose(b));
but it’s not work ok.
how can I resolve this issue?
dave_59
September 1, 2024, 3:23pm
2
Please format your code making your code easier for others to read. I have done that for you.
You would do the same way as shown here , except that a and b become your two clocks.
Brurya
September 2, 2024, 6:29am
3
Thanks @dave_59 .
it seems that the example you gave me, is how to implement clock period checker, not?
I look for how to implement
|-> ##[10:$]
10 value should be variable.
Thanks.
I guess (1,delay=delay-1) [*0:$] ##0 delay <= 0 should be (1,delay=delay-1) [*0:$] ##1 delay <= 0.
Please refer to the following. I believe they are helpful to you.
sva_repeat_delay_thru_pkg_011624.sv
sva_repeat_delay_thru_pkg_011624.pdf (89.0 KB)
Brurya
September 2, 2024, 9:01am
5
Thanks @Orimitsu
It works to me.
I’ll be happy if you can explain the code, in order to understand what more I can check with it.
Thank a lot.
Hi @Brurya ,
[*1:$] ##1 delay <= 0 is non overlapping while [*1:$] delay ##0 delay <= 0 is overlapping.
That is, delay value is evaluated after count down in non overlapping. On the other hand, delay is evaluated at the same cycle of count down.
[1:$] ##0 delay <= 0
| Count Down Sequence |
| -1 -1 -1 -1|
delay : | v_delay ... 3 2 1 0
Overlap ->| delay <= 0 ?
[1:$] ##1 delay <= 0
| -1 -1 -1|
Non Overlap ->| definetely delay <= 0
I guess the value of delay at the evaluation cycle is not deterministic in case of overlapping.
dvfunda
September 4, 2024, 3:17pm
8
Why do we need to specify ##1 delay <= 0 ? Shouldn’t it be ##1 delay == 0?
Hi @dvfunda ,
To avoid delay value decrement and its evaluation at the same clock cycle. The value of delay is definitive in the next clock cycle.
dvfunda
September 5, 2024, 9:57am
10
Hi @Orimitsu ,
Thanks for the reply. My doubt was regarding delay <= 0. I believe, delay will be 0 at the last cycle.
Hi @dvfunda ,
Oh, I see. delay == 0 also works. I guess delay <= 0 is only for just in case. Ben Cohen’s sample sequences is in such a style.
I think a lot of people is referring to them.
dvfunda
September 6, 2024, 4:37am
12
Hmm, Thanks @Orimitsu for the clarification.
