HI All,
consider the following property to find a glitch
property p1(clk);
realtime first_change;
@(clk)
('1, first_change=$realtime)|=>$realtime-first_change>=2ns;
//time period between 0->1 and 1->0 should not be less than 2ns, if yes its a glitch.
Keeping the same concept in mind, Now i have written the assertion
to find the difference between two clocks in terms of freq or time duration.
If clk1 is 100mhz, that is 10ns, clk2 should also be the same.
In case if there is a difference, assertion should fail
This is the following code, its not working as expected.
Assertion is failing for every clock, even though I have generated the same clock
module two_clk_assertion;
logic clk1, clk2;
property p1(clk1, clk2);
@(clk1)
('1, first_change=$realtime)|=>$realtime-first_change==clk2;
L1: assert property (@(posedge clk1) p1(clk1, clk2))
$display("TIME: ====FPV PASS=====", $time);
$display ("**FPV FAIL**");
clk1=0;
clk2=0;
#100 $finish;
initial forever #5 clk1 = ~clk1;
initial forever #5 clk2 = ~clk2;
$dumpfile("dump.vcd"); $dumpvars;
Kindly suggest how can I modify or update the code to find the difference in two clocks.
Thank you,
