In reply to sumanth291092:
Using the example where we address clk1 by itself.
The concept is to keep track of the clk1 being active or not active, then using an immediate assertion to check that if in ST0, the active1 variable is true.
http://systemverilog.us/vf/alive.sv // code with tb
http://systemverilog.us/vf/alive.png // image of code and simulation
3 parts to this code:
- An initial that fires a task and waits till it’s done
- A task with a fork join to see which forks finish first. If it’s the clock, then active==1, if it’s a #P1 then active1=0. done gets set, the e event is for debug
- The assertion. I used a #10 after the done before checking because of the asynchronous nature of when the state changes state and when I can relably detect if the clk1 is active.
Adjust this as needed. Other immediate assertions can be written based on state=ST1.
/* I have two states s0 and s1, and three clocks clk1, clk2, clk3.
In s0 state clk1 and clk2 are active, and in s1 state clk3 is active.
I need to fire an assertion when in state s0 if no clk is detected
(in this case clk1 and clk2) and when in state s1 if clk33 is not detected. */
module top;
// `include "uvm_macros.svh" import uvm_pkg::*;
typedef enum {ST0, ST1} st_t;
bit clk0=0,clk1, clk2, clk3;
bit active1, active2, active3;
st_t state;
bit done, err;
event e;
let P1=7; let P2=8; let P3=10; // periods of the clocks
initial forever #3 clk0 = !clk0; // for test
always_comb if (err) clk1=1'b0;
else if (state==ST0) clk1= clk0;
else clk1=1'b0;
initial forever begin : ALIVE1
t_clk1();
wait (done); //@ (done);
done=0;
task automatic t_clk1();
fork
PERIOD1: begin
#P1;
active1=1'b0;
disable CLOCK1; // ADDED
CLOCK1: begin
@(clk1);
active1=1'b1;
disable PERIOD1;
join_any
done=1; ->e;
always begin
@(posedge done);
#10 if(state==ST0) am_st0_clk1: assert(active1);
always begin // FSM
repeat(3) begin
#100 state= ST0;
#100 state=ST1;
err=0;
#22 err=1; ; // error injection
#44 err=0;
- SVA Package: Dynamic and range delays and repeats SVA: Package for dynamic and range delays and repeats - SystemVerilog - Verification Academy
- Free books: Component Design by Example https://rb.gy/9tcbhl
Real Chip Design and Verification Using Verilog and VHDL($3) https://rb.gy/cwy7nb - Papers:
Verification Horizons - SVA Alternative for Complex Assertions
https://verificationacademy.com/news/verification-horizons-march-2018-issue - SVA in a UVM Class-based Environment
