n347
February 19, 2020, 12:32am
1
Can you please help me with this interview question?
There was a black box which has 8 pairs of input and a single 8 bit output. Each pair in the input has one single bit valid line, and 8 bit input line. When there is change in the status of any of the valid input bit, corresponding input is sampled to black box and there will be change in output. Write an assertion to check if at least 4 bits of the sampled output is changed during the process.
ben2
February 19, 2020, 8:44pm
2
In reply to n347 :
bit[7:0] valid;
byte data[7:0];
// For a single input/output pair
ap_valid0: assert property(@ (posedge clk)
$changed(valid[0]) |=> $countones($past(data[0]) ^ data[0])==4 );
// For al 8 pairs
generate for (genvar i=0; i<=7; i++)
ap_valid: assert property(@ (posedge clk)
$changed(valid[i]) |=> $countones($past(data[i]) ^ data[i])==4 );
endgenerate
Testbench
bit clk;
bit[7:0] valid;
byte data[7:0];
initial forever #10 clk=!clk;
endgenerate
bit va, vb;
repeat(200) begin
repeat(1) @(posedge clk);
if (!randomize(valid, data)) `uvm_error("MYERR", "This is a randomize error");
$stop;
SVA Alternative for Complex Assertions
Verification Horizons - March 2018 Issue | Verification Academy
SVA: Package for dynamic and range delays and repeats | Verification Academy
SVA in a UVM Class-based Environment
