I have the following property/assert command:
property check;
@(negedge kill) disable iff (!poreset_b) (use_ratio_x2 == (2 * ratio)) ;
assert_check: assert property (check)
$display("##### FAILURE: Assertion check failed. #####");
The assertion is failing at time 0, even though poreset_b = 0 at time 0fs.
Please help.
In reply to pRoSpEr :
Is it because poreset_b starts uninitialised at time 0 before transitioning to 0?
If so, then changing to “disable iff (poreset_b !== 1’b1)” may solve your problem.
Richard
user49
June 12, 2015, 11:24pm
3
In reply to Richard Hamer (EnSilica) :
If the following property
is used once at setup, there is no need to check it at every clocking event. In that case, instantiate the assertion within an initial block.
SystemVerilog Assertions Handbook 3rd Edition, 2013 ISBN 878-0-9705394-3-6
A Pragmatic Approach to VMM Adoption 2006 ISBN 0-9705394-9-5
Using PSL/SUGAR for Formal and Dynamic Verification 2nd Edition, 2004, ISBN 0-9705394-6-0
Real Chip Design and Verification Using Verilog and VHDL, 2002 isbn 0-9705394-2-8
Component Design by Example ", 2001 ISBN 0-9705394-0-1
VHDL Coding Styles and Methodologies, 2nd Edition, 1999 ISBN 0-7923-8474-1
VHDL Answers to Frequently Asked Questions, 2nd Edition ISBN 0-7923-8115
