Assertion does not fail!
Thanks much, Dave. Your first solution actually does exactly what I want. The only difference is that my spec expected the entire sequence to start with $rose(tagError). But checking for level sensitive tagError will work. I should have thought of moving part of the expression as an antecedent.
Your second solution has a typo (mCheck is repeated twice). Should be,
property p1;
@(posedge clk)
tagError && ($rose(tErrorBit) | $rose(mCheck)) |-> $rose(mCheck) && $rose(tErrorBit);
Thanks again.
