Assertion Check
In reply to rkg_:
After every successful antecedent, a new thread is fired, and that thread is independent of any other previously fired thread. That can cause errors if you want to check the packets independently. Below is a simulatable example where I used the block.
/*property p_lock_condition_check_unlock_prog_00_v0; // OK too, using the |=> (consequent)
    int inc_count, dec_count;
    @(posedge sampled_monclk) disable iff (!i_en_fll)
      ( (o_fll_sar_eoc == 1) && i_fll_unlock_prog == 2'b00, inc_count=0, dec_count=0)   |=>
            (1, inc_count+= $rose(o_fll_inc), dec_count+= $rose(fll_dec))[*1:6] ##0
            o_fll_lock==(inc_count==2 || dec_count==2);
This assertion is failing even after lock is asserted ( just after 6 posedge of sampled_monclk after lock assertion ).
Do we need to put some extra logic so that one lock is asserted it should not check until the next packet will come ? */
module top;
    timeunit 1ns;  timeprecision 100ps;
    `include "uvm_macros.svh"     import uvm_pkg::*;
    bit clk, a, b, c, reset_n, block;
    initial forever #10 clk = !clk;
    function void set_block(bit x);
        block=x;
    ap_a2b2c: assert property(@ (posedge clk)
       $rose(a) |-> ##1 ((b[=2] or c[=2]) intersect 1[*1:6]));
    ap_a2b2cBLOCK: assert property(@ (posedge clk)
       ($rose(a) && block==0, set_block(1)) |-> ##1 ((b[=2] or c[=2]) intersect 1[*1:6]))
         set_block(0); else set_block(0) ;
      repeat (200) begin
        @(posedge clk);
        if (!randomize(a, b, c) with {
          a dist {1'b1 := 1, 1'b0 := 3};
          b dist {1'b1 := 1, 1'b0 := 4};
          c dist {1'b1 := 1, 1'b0 := 4};
          `uvm_error("MYERR", "This is a randomize error");
      $finish;
