HI All,
I am writing an assumption for the following requirement;
valid is an input signal. I want to constraint/write assume, once it goes HIGH, it should remain HIGH for at least 6 clock cycles and then it should go low.
I have written like this;
assume property (
@(posedge clk)
//$rose(valid) |-> ##[6:8] !valid; //case_1
$rose(valid) |-> ##[6:8] $fell(valid)
); //case_2
both cases are not working as expected. After running this,
cover precodnition (antecedent) is getting passed,
but cover witness is getting undermined.
Result : property is keep running, looks like some issue.
Could you please suggest what could be wrong here?
