Assertion - Accesing signals of a .vhdl file from .sv file
Hello All,
I would like to write assertions for a VHDL RTL, so my intention is
abc.vhdl (Top VHDL file , all port mapping of sub blocks are done here)
wrap.sv (instantiates the abc.vhdl file, this will be used by my verif environ)
int_rest (internal signal in abc.vhdl , this does not reach the IO of abc.vhdl)
Now my intention is to write system verilog assertions on the internal signal ‘int_rest’, so i would like to access this internal signal from the wrap.sv (where all my assertions will sit).
Please assist me in achieving this.
Maximus
You need to use the SystemVerilog bind command that inserts a SV module with assertions inside a VHDL entity. If you are using Questa, look in the user guide for the section Using SystemVerilog bind Construct in Mixed-
Language Designs
You have few choices:
  1. As Dave said, use SV bind feature - and bind it to entity-architecture pair, that way your SV can see internal signals too. Below is a single slide from our SVA-VHDL training that we recently delivered to a customer who had similar requirement.
  1. You can use VHDL-2008 “extern” signal feature to bring internal signals to a top level VHDL and use. Also see: http://verificationacademy.com/forum/verification-methodology-discussion-forum/systemverilog-and-other-languages-forum/20411-question-related-sv-binding
  2. PSL is now part of VHDL and hence one could potentially stay within VHDL and achieve all of these - if desired.
HTH
Ajeetha, CVC
