We have a requirement like below.
If we have a 5K memory space and every time we can randomly select a successively space with the size = 100. But we can not allocate the overlap memory space. May I know what’s the best way to implement it in constraint ?
In reply to zz8318:
//We have a requirement like below.
//If we have a 5K memory space and every time we can randomly select a successively space with the size = 100. But we can not allocate the overlap memory space. May I know what's the best way to implement it in constraint ?
class goalie;
rand int start_addr;
rand int end_addr;
rand int mem_block[500];
rand int block;
rand int block_start;
rand int block_end;
int mem_track[500];
constraint ab {
block == 100;
start_addr ==0;
end_addr ==500;
block_start inside {[0:499]};
block_end < end_addr;
block_start > start_addr;
block_end == block_start+block-1;
foreach (mem_track[i]) {
if (mem_track[i]==i) block_start !=i;
if (mem_track[i]==i) block_end !=i;
for (int i=block_start;i<=block_end;i++) begin
mem_track[i] = i;
module tb;
goalie g1;
initial
g1 = new;
repeat (3) begin
if (!g1.randomize()) $display ("Erorr");
$display ("block_start %d, block_end %d",g1.block_start,g1.block_end);
$display ("start_addr %d, end_addr %d",g1.start_addr,g1.end_addr);
