Array.sum method is not working as expected
If Change the size of A I am not getting the expected value can anyone help me why I am getting unexpected values
class C;
  rand bit [7:0] A[] ; //if my bit value is 7:0 is getting expected value
constraint c1 { A.size == 5; }
  constraint c2 { A.sum() with (int'(item)) < 1000; }
  C A[10];
  initial
      foreach(A[i])
          A[i] = new();
          assert(A[i].randomize());
          $display(" %p", A[i].A);
run -all
'{52, 116, 27, 117, 9}
'{234, 128, 109, 243, 251}
'{103, 191, 223, 56, 62}
'{1, 143, 120, 157, 215}
'{130, 119, 51, 54, 248}
'{171, 55, 70, 59, 18}
'{134, 194, 18, 241, 91}
'{94, 212, 232, 79, 11}
'{20, 120, 110, 206, 223}
'{227, 253, 171, 58, 124}
exit
class C;
  rand bit [31:0] A[] ;
  C A[10];
  initial
      foreach(A[i])
          A[i] = new();
run -all
'{3787357203, 205694960, 2308197910, 665118826, 4247110087}
'{972731610, 465127672, 2710588818, 3501954850, 3456330263}
'{3020650510, 1576741973, 3787254651, 372673491, 3891600393}
'{2634639171, 62035855, 3195722274, 123205191, 1369482221}
'{3523790041, 2686765230, 13219328, 2036180016, 3200139311}
'{3393038216, 1966423041, 2557274573, 715508048, 3743281444}
'{3428203505, 3012590047, 417466824, 3765525831, 1945975121}
'{390926889, 2541436557, 4244306482, 2478460877, 1509793635}
'{857388233, 2403345028, 3597653875, 1111139865, 3163724970}
'{2533588731, 1202244656, 764513822, 3665321193, 2591416844}
exit
In reply to marathuteja:
Your constraint does not handle overflow. Try:
  constraint c2 { A.sum() with (64'(item)) < 1000; }
@dave_59
I tried below example but not seeing expected results. Would you help me fix it ?
i expect all items to be within 5 and 10.
class C;
  constraint c2 { A.sum() with (int'(item)) inside {[5:10]};
  C A[10];
  initial
      foreach(A[i])
          A[i] = new();
# run -all
#  '{3, 1, 2, 0, 0}
#  '{4, 2, 0, 3, 1}
#  '{2, 1, 5, 1, 0}
#  '{1, 3, 0, 0, 6}
#  '{4, 0, 0, 1, 1}
#  '{2, 0, 2, 5, 1}
#  '{0, 1, 5, 4, 0}
#  '{2, 2, 0, 4, 2}
#  '{0, 1, 4, 4, 1}
#  '{3, 2, 4, 0, 0}
PS: Sorry I do not the way to format the source code. Im new here, appreciate if you tell me how to format this.
Look at this link “format your code” making your code easier for others to read. I have done that for you.
Your constraint makes the sum of the array A to be inside the range 5 to 10. If you want each element of A to be inside that range, then the constraint would be
foreach (A[i]) A[i] inside {[5:10]};
