Array Size is not getting allocated properly
Hai All,
Here is my sample code :
module tb;
  bit[15 : 0] cnt1;
  bit[15 : 0] cnt2;
  int cnt1xcnt2;
  //int cnt2;
  bit[7 : 0] data[];
    void'(std :: randomize(cnt2)with{cnt2 == 'd4;});
    void'(std :: randomize(cnt1)with{cnt1 == 'd54004;});
    $display("CNT1 %0d",cnt1);
    $display("CNT2 %0d",cnt2);
    cnt1xcnt2 = cnt1*cnt2;
    data = new[cnt1*cnt2];
    $display("array size before randomization : %0d",data.size());
    void'(std :: randomize(data) with {data.size() == cnt1*cnt2;});
    $display("array size after randomization : %0d",data.size());
endmodule : tb
I am seeing this in the log
CNT1 54004
CNT2 4
array size before randomization : 19408
array size after randomization : 216016
There’s a mismatch in the expected size when i call the new method for the dynamic array initialization.
Can anyone provide some inputs here,
Here’s my EDA link : EDA Playground
If you try the other simulators, you will notice different results.
For the simulator you have specified, you are seeing the results of two 16 bit values being multiplied and being stored as a 16 bit value. To ensure correct results, you will want to cast the multiplication to an int so that there won’t be any overflow.
