I am expecting the result queue to be populated with the number equal to the one present both in arr and q. The below equation i have doesnt give expected result.
module top();
int q[$];
int result[$];
int arr[$];
arr = {9,1,8};
q = {9, 1, 8, 3, 4, 4};
$display("1. queue 'q' in decimal : %p", q);
result = q.find(i) with (i == arr[i]);
$display("1. find with i inside arr[i] : %p",result );
endmodule : top
Expected result[$] = 9,1,8;
In reply to rag123:
module top();
int q[$];
int result[$];
int arr[$];
arr = {9,1,8};
endmodule : top
I think you just need to use
result = q.find(i) with (i == arr[i.index]});
Regarding your code ask yourself this, what would be the value when i=9, of are[9]?
HTH,
-R
In reply to rag123:
I think i got it working.
result = q.find(i) with (arr[i] == q[i]);
but i am not sure why the below one is not working, they both are same?
result = arr.find(i) with (arr[i] == q[i]);
In reply to rag123:
i represents each element of the queue/array not the index, you may need to use i.index
Also I’m not sure if I understand your question do you want to find all the elements of q that are present in arr irrespective of their position, or do you want to find if q[0] == arr [0] and so on.
In reply to rag123:
module top();
int q[];
int result[];
int arr[$];
arr = {9,1,8};
$display(“1. queue ‘q’ in decimal : %p”, q);
**//result = q.find(i) with (i == arr[i]);
foreach (arr[i]) begin
result.push_back(int’(arr.find_first(x) with (x == q[i])));
$display("1. find with i inside arr[i] : %p ",result );
endmodule : top
In reply to mannat:
You need to clarify a few things. Does it matter which array might have more elements? How are repeated values handled? For example what would you expect the result of this to be?
arr = {9,1,8,4,6,5,5,5};
q = {9, 1, 8, 3, 4, 4, 5};
No it doesn’t.
I want all the values irrespective of unique.
Later i will unique those values from result queue.
In reply to rag123:
module top();
int q[$];
int result[$];
int arr[$];
$display("q : %p", q);
$display("arr : %p", arr);
foreach (arr[i])
if (arr[i] inside {q})
result.push_back(arr[i]);
result = result.unique();
$display("result : %p ",result );
endmodule : top
