Array of ints to array of bytes (using streaming operator)
I need to convert a dynamic array of ints to a dynamic array of bytes, in the right order:
The first byte should be the least significant bits of the first integer. I wanted to do this using the streaming operator, but this seems to reverse either the int order or the byte-in-int order:
        int unsigned int_data[]=new[3];
        byte unsigned byte_data[];
        int_data[0]=0;
        int_data[1]=1;
        int_data[2]=2;
        byte_data={<<byte{int_data}};
        foreach(byte_data[z]) begin
            $display("  %0d",byte_data[z]);
This prints:
2
0
0
0
1
0
0
0
0
0
0
0
So the order of the ints is wrong. I really need it to be:
0
0
0
0
1
0
0
0
2
0
0
0
Using >> gets the int order right, but the byte order wrong.
I tried some things using the ‘with’ extension, but can’t figure out how to use it.
In reply to Nico75:
How about doing reverse() on the array prior to streaming? Try:
module m;
  initial begin : b1
        int_data[0]=0;
        int_data[1]=1;
        int_data[2]=2;
    int_data.reverse();
  end : b1
Regards
Srini
www.verifworks.com
In reply to Srini @ CVCblr.com:
Good suggestion, that will definitely work. Just a little bit concerned about the efficiency.
In reply to Nico75:
You can do this in one line, but I don’t know how much more efficient it will be.
byte_data={<<byte{{<<int{int_data}}}};
You might also try
byte_data = new[4*int_data.size()];
foreach(int_data[z])
    byte_data[z*4 +:4] = {<<byte{int_data[z]}};
