While I was reading about the array.max function, I see the return type is a queue. I would like to understand why the return of max on an array of values have to be a queue, rather than a single value of the same data type of the original array.
Thanks in advance,
Madhu
In reply to mseyunni:
All of the array locator methods have the same prototype, and for some of them, it is possible to return an empty set.
Ok. My question was mainly why does the return type have to be a queue instead of a single value of that type?
How would you suggest retuning an empty value?
Did you mean max function applied on a empty array? If it is empty array, then the compiler can throw an error. Otherwise, if there is a int q[3], with 3 values 4, 7 and 9. Then I would expect the max function returning a value of 9 as int.
The compilier does not know if the array is empty, you only know at runtime. As far as I know, some languages will throw a runtime error if you try a max/min on an empty array. Since SV does not have exceptions, I guess returning a queue was the most pragmatic approach (and keeps the function prototypes the same as Dave mentioned).
In reply to nzicha_acd:
Yes. I agree, the issue needs to be caught during run-time.
