LRM 2012 18.5.8.1 :: " If an array is constrained by both size constraints and iterative constraints, the size constraints are
solved first and the iterative constraints next. "
[ Q1 ] By iterative Constraint does it mean Only foreach or foreach as well as Array Reduction Methods like sum()
[ Q2 ] Do the size constraint and iterative constraint Need to 2 separate Constraints
eg :
constraint SIZEE { b.size() inside { [ 1:MAX ] } ; }
constraint ITERATIVE {
foreach ( b[k] )
(k < b.size - 1) -> b[k + 1] > b[k];
Or can they be a Part of same Constraint
eg :
constraint ONE { b.size() inside { [ 1:MAX ] } ;
foreach ( b[k] )
Here is an Example I was trying
module Array_Constrained_by_Both_size_constraint_AND_iterative_constraint;
parameter MAX = 10 ;
class A ;
bit [3:0] b [];
constraint SIZEWA { b.size() inside { [ 1:MAX ] } ; }
foreach ( b[k] )
A a1;
a1 = new();
repeat ( 10 )
if ( ! a1.randomize() )
$display("ERROR");
foreach(a1.b[i])
$write(" b[%0d] == %0d ",i,a1.b[i]);
$display();
Now i got an ERROR all 10 Times , I assumed it might be due to older version of Simulator so I tried adding a Constraint ::
constraint ORDERING { solve A::SIZEWA before A::ITERATIVE ; } // Error
{Q3 ] Any other Way i can Modify the Code above ?
[Q4] When randomizing a Dynamic Array of Handles can the size Constraint solved before Iterative Constraint be taken advantage of ?
class Object;
rand int id;
class Objects;
rand Object lst[];
constraint size_c { lst.size() inside {[1:5]};}
// Need to add Iterative Constraint
Now the iterative constraint should be something like ::
lst = new[size]; // Will this Work in a Constraint ?
foreach (lst[i]) begin // This Would Work but should Iterate after new[]
lst[i] = new;
lst[i].id = i;
