I have a APB Slave which i am validating with UVM TB. I see the write’s are going through, but the read always return’s X. I have tried couple of ways but nothing helps. Can anyone help to see why the rdata is always X?
In reply to rag123:
You are reading from addresses you do not write before and your protocol in the monitor is wrong wrt to RD.
Additionally your convert2string prints only pwdata.
Hi Chris,
I dont see anything wrong in the code. In the waves i dont the address actually changing for read and write. I added conver2string print for rdata. which part of the monitor code is wrong?
In reply to rag123:
See the modified example here:
Only your monitor code is wrong for the RD. When you are providing the address you’ll see the RD data 1 clock cycle later.
And you test is useless. You are writing to certain addresses and you are reading from other addresses. This results in the RD vale ‘=’.
I see you have removed the 1 clock cycle delay in the monitor for prdata. I still dont see in the waves the prdata has a valid value. It is still X. what did you fix?
In reply to rag123:
No, I was adding another clock cycle in the monitor.
See the log-file here:
UVM_INFO @ 20: uvm_test_top.env.agt.drv [APB_DRIVER ] Got Transaction kind=WRITE addr=57 data=66
UVM_INFO @ 50: uvm_test_top.env.agt.mon [APB_MONITOR] Got Transaction kind=WRITE addr=57 data=66
UVM_INFO @ 50: uvm_test_top.env.agt.mon [APB_MONITOR] Got Transaction after waiting
UVM_INFO @ 60: uvm_test_top.env.agt.drv [APB_DRIVER ] Got Transaction kind=READ addr=85 data=d2
UVM_INFO @ 90: uvm_test_top.env.agt.mon [APB_MONITOR] Got Transaction kind=READ addr=85 data=0
UVM_INFO @ 90: uvm_test_top.env.agt.mon [APB_MONITOR] Got Transaction after waiting
UVM_INFO @ 110: uvm_test_top.env.agt.drv [APB_DRIVER ] Got Transaction kind=READ addr=ea data=95
UVM_INFO @ 140: uvm_test_top.env.agt.mon [APB_MONITOR] Got Transaction kind=READ addr=ea data=0
UVM_INFO @ 140: uvm_test_top.env.agt.mon [APB_MONITOR] Got Transaction after waiting
UVM_INFO @ 160: uvm_test_top.env.agt.drv [APB_DRIVER ] Got Transaction kind=WRITE addr=34 data=78
UVM_INFO @ 190: uvm_test_top.env.agt.mon [APB_MONITOR] Got Transaction kind=WRITE addr=34 data=78
UVM_INFO @ 190: uvm_test_top.env.agt.mon [APB_MONITOR] Got Transaction after waiting
UVM_INFO @ 200: uvm_test_top.env.agt.drv [APB_DRIVER ] Got Transaction kind=READ addr=fb data=bb
UVM_INFO @ 230: uvm_test_top.env.agt.mon [APB_MONITOR] Got Transaction kind=READ addr=fb data=0
UVM_INFO @ 230: uvm_test_top.env.agt.mon [APB_MONITOR] Got Transaction after waiting
UVM_INFO @ 250: uvm_test_top.env.agt.drv [APB_DRIVER ] Got Transaction kind=WRITE addr=e data=ee
UVM_INFO @ 280: uvm_test_top.env.agt.mon [APB_MONITOR] Got Transaction kind=WRITE addr=e data=ee
UVM_INFO @ 280: uvm_test_top.env.agt.mon [APB_MONITOR] Got Transaction after waiting
UVM_INFO @ 290: uvm_test_top.env.agt.drv [APB_DRIVER ] Got Transaction kind=WRITE addr=c6 data=f6
UVM_INFO @ 320: uvm_test_top.env.agt.mon [APB_MONITOR] Got Transaction kind=WRITE addr=c6 data=f6
UVM_INFO @ 320: uvm_test_top.env.agt.mon [APB_MONITOR] Got Transaction after waiting
UVM_INFO @ 330: uvm_test_top.env.agt.drv [APB_DRIVER ] Got Transaction kind=WRITE addr=46 data=c4
UVM_INFO @ 360: uvm_test_top.env.agt.mon [APB_MONITOR] Got Transaction kind=WRITE addr=46 data=c4
UVM_INFO @ 360: uvm_test_top.env.agt.mon [APB_MONITOR] Got Transaction after waiting
UVM_INFO @ 370: uvm_test_top.env.agt.drv [APB_DRIVER ] Got Transaction kind=WRITE addr=89 data=dd
UVM_INFO @ 400: uvm_test_top.env.agt.mon [APB_MONITOR] Got Transaction kind=WRITE addr=89 data=dd
UVM_INFO @ 400: uvm_test_top.env.agt.mon [APB_MONITOR] Got Transaction after waiting
UVM_INFO @ 410: uvm_test_top.env.agt.drv [APB_DRIVER ] Got Transaction kind=READ addr=92 data=5d
UVM_INFO @ 440: uvm_test_top.env.agt.mon [APB_MONITOR] Got Transaction kind=READ addr=92 data=0
The UVM_INFO from the driver is wrong in case of the RD, because the convert2string returns only the write data.
In reply to rag123:
Your DUT is not working. Data are not stored in the mem.
Please find your fixed example here:
Thanks Chris :)
