Can we do logical and operation between two `defines? If so how?
For ex:
I have two defines A and B.
I need result like:
ifdef A && B //both should be enabled at a time $display("Both are defined"); else
$display(“Some operation must happen”);
`endif
In reply to Swetha Reddy E:
I suggest that you first see if there is a way of doing what you want without using ``ifdefs
But if not, you can do things like
`ifdef A
`define A_or_B
`ifdef B
`define A_and_B
`endif
`elsif B
`define A_or_B
`endif
`ifdef A_and_B
`else
$display("Both are not defined");
`endif
